Question data-vocabulary.org to schema.org
pdobrott
Google sent an email warning of breadcrumbs data-vocabulary.org.
Warnings are suggestions for improvement. Some warnings can affect your appearance on Search; some might be reclassified as errors in the future. The following warnings were found on your site:
data-vocabulary.org schema deprecated
Searching templates dbtech_dbseo_navbit template is using the data-vocabulary.org.
<vb:if condition="$show['breadcrumb']">
<li class="navbit" itemscope="itemscope" itemtype="http://data-vocabulary.org/Breadcrumb"><a href="{vb:raw nav_url}" itemprop="url"><span itemprop="title">{vb:raw nav_title}</span></a></li>
<vb:else />
<li class="navbit lastnavbit"><span itemprop="title">{vb:raw nav_title}</span></li>
</vb:if>
Do you have an update to convert data-vocabulary.org structured data to schema.org that will appease the google gods?
Thanks
