Question cost formula per kg
Sorry, I don't understand the question. You can't set up weight tiers like that, as the shipping method is set per item, not per order.
The easiest thing to do would be to set a base price per kg, which could be something like 8 * w which would be €8 for 1kg, €16 for 2kg etc.
I wrote (10 * w)
I did a test order, 2 items, 0.1 KG each, so total of 0.2 Kg for the order
and into order page I see this total
Sub-total €10.00
Sale discounts -€0.00
Coupon discounts -€0.00
Shipping cost +€4.00
Order total €14.00
why shipping cost is just 4 euro? should be 10 euro
so when you suggested this? it's not correct?
It was correct, but if your items are less than 1 kg you'll need to adjust the formula accordingly.
4.86 star(s) 7 ratings
