Question Cms disappeared - Please Help
Also these pages aren't reachable:
http://www.sigarettaelettronicaforum.com/notizie-importanti/5122-sangalli-pd-modifica-limposta-del-consumo-nella-misura-pari-al-25%.html
http://www.sigarettaelettronicaforum.com/eliquids-e-mixing/8731-consiglio-liquido-60%vg-40%pg.html
http://www.sigarettaelettronicaforum.com/eliquids-e-mixing/8797-base-%-vg-pg-h2o.html
http://www.sigarettaelettronicaforum.com/eliquid-pronti-ed-aromi/8108-liquido-pronto-100%-vg.html
I'm seeing the the links with specials symbols like "%" or "[" are not accepted as links.
But before they were working.
I have also to let you know that I have changed the codify of Italian Language in the "languages and phrases" option.
Before was ISOand I don't remember what... and then I changed with utf8.
I made this just when I moved the site on the new server.
Also for example now is arrived another blog error:
Database error in vBulletin 2.0.32:
Invalid SQL:
                    SELECT userid
                    FROM vb4_user
                    WHERE username REGEXP '^(&[\#\da-z]*;|[^a-z\d])*bl[oÒÓÔÕÖØòóôõöø]g.html(&[\#\da-z]*;|[^a-z\d])*$'
                    LIMIT 1;
MySQL Error   : Got error 'invalid UTF-8 string at offset 26' from regexp
Error Number  : 1139
Request Date  : Saturday, May 14th 2016 @ 09:08:57 PM
Error Date    : Saturday, May 14th 2016 @ 09:08:57 PM
Script        : http://www.sigarettaelettronicaforum.com/members/forrest/blog.html/
Referrer      :
IP Address    : 40.77.167.23
Username      : N/A
Classname     : DBSEO_Database_MySQLi
MySQL Version :
But the right link for the blog of this user for example should be:
http://www.sigarettaelettronicaforum.com/blogs/forrest/
I don't know if this can help but I had also to disable the cms friendly urls, because if I enable it the cms page isn't loaded, but I would like to re active it.
Can you try changing the Non-Latin Characters setting to Replace Non-Latin Characters and see if that helps?
Fillip now it look to go better.
I'm not receiving utf8 errors (I mean with symbols corrupted)
The only thing I'm seeing that each time I go on the blog of each user, this for example:
Sigaretta Elettronica Forum - Markvaping68 - Prodotti
Arrive me this error:
Invalid SQL:
SELECT blogcategoryid AS id FROM vb4_blog_category WHERE userid IN(0,2474) AND title REGEXP "^(&[\#\da-z]*;|[^a-z\d])*(&[\#\da-z]*;|[^a-z\d])*[aÀÁÂÃÄÅàáâãäå](&[\#\da-z]*;|[^a-z\d])*(&[\#\da-z]*;|[^a-z\d])*$" ORDER BY LENGTH(userid IN(0,2474) AND title) LIMIT 1;
MySQL Error   : Got error 'invalid UTF-8 string at offset 45' from regexp
Error Number  : 1139
Request Date  : Saturday, May 14th 2016 @ 10:52:53 PM
Error Date    : Saturday, May 14th 2016 @ 10:52:53 PM
Script        : http://www.sigarettaelettronicaforum.com/blogs/markvaping68/a/
Referrer      :
IP Address    : 93.58.31.180
Username      : N/A
MySQL Version :
Edited
Is there the name of this user "mister.mai"
but if I try to go on him page:
http://www.sigarettaelettronicaforum.com/members/mister.mai.html
you will see that the system will redirect to:
http://www.sigarettaelettronicaforum.com/members/mister-mai.html
and the page not appear.
I would strongly recommend adding the [user_id] parameter to your member page URLs, for this exact reason.
The problem that I still see is that the plugin send me an error for each time a tag is searched but is not contained in the memory.
If you try to search a tag that is different of those words proposed, the site crash.
I receive this message:
Invalid SQL:
SELECT tagtext AS id FROM vb4_tag WHERE tagtext REGEXP "^(&[\#\da-z]*;|[^a-z\d])*(&[\#\da-z]*;|[^a-z\d])*p[iÌÍÎÏìíîï][aÀÁÂÃÄÅàáâãäå](&[\#\da-z]*;|[^a-z\d])*(&[\#\da-z]*;|[^a-z\d])*$" ORDER BY LENGTH(tagtext) LIMIT 1;
MySQL Error   : Got error 'invalid UTF-8 string at offset 46' from regexp
Error Number  : 1139
Request Date  : Sunday, May 15th 2016 @ 12:55:30 AM
Error Date    : Sunday, May 15th 2016 @ 12:55:30 AM
Script        : http://www.sigarettaelettronicaforum.com/tags/pia.html
Referrer      :
IP Address    : 68.180.229.241
Username      : N/A
MySQL Version :
This is my email folder this morning.
If you see the errors arrives at all the hours all the night, also where don't should be anyone.
