Question Automatically Converting Currency (or Allowing Decimal Values)
kbryant414
Looking at the add-on, I feel like this should be possible, but I haven't figured out how to, yet.
A use-case scenario: user posts an article in a designated forum, I want to be able to give currency by the word count. I can do that without issue (this add-on is pretty great). However, I want to give currency at a rate of 1 per 10 words, or 0.1 per word. Since this doesn't appear to be an option, I thought an alternative would be to have two currencies, one with a value of 1 (Pennies) and the other with a value of 100 (Dollars). The idea would be that they would earn Pennies initially, then have it converted to Dollars they can use in the DBShop.
The currency has been in use on a previous forum, so I don't want to just increase prices users are familiar with from, say, 250 to 25000, although that is an option if nothing else works. I'm hoping to add a bit more automation to the earning rather than requiring manual adjustment for each payment as I've done in the past.
Am I missing something simple? Or if it isn't possible, is it plausible to add the functionality?
Decimals are definitely supported, I've tested it in the XF2 versions just now and I am able to save using decimals for the Words / Characters options :)
Did you try entering the value manually rather than using the steps?
I did, yes. It highlights the field in red and says, "Please select a valid value. The two nearest values are 0 and 1." I do know there is the option to round decimals or display them, but where I'm actually having the problem is setting a "Post" Event to award 0.01 credits per word. The goal is that if a user makes a 1,000 word post (in the designated area), they should get 10.00 in the currency.
I tested the idea itself, and it works well as long as I have both a "Thread" Event and a "Post" Event (as the Post event doesn't seem to capture the first post in a thread). The word counting seems accurate, it's quick, rewarding, and simple. The add-on is really impressive. My only problem is that I can't get 1000 Words = 10 Currency, the lowest I can get is 1000 Words = 1000 Currency. To get decimals I have to manually "Adjust" them, as far as I can tell.
I had thought that it must be limited to integers for a reason if it was giving me that error message, which is why I was brainstorming a way to work around it without asking for a feature change. From your response, it seems like it's supposed to allow decimals in the events, though? I've included screenshots below, starting from a fresh reinstall of DBCredits.
As a quick aside, this is a minor, separate issue, but I can't seem to Edit existing currencies. When I try, the Save button is missing, and it will only let me make duplicate currencies. It's included in the screenshots below, at the bottom.
What browser are you using? This does not occur for me in Chrome (latest) on Windows 10.
I was using Firefox (57.0.1). I just tested on the latest version of Chrome (62.0.3202.94) and it does not do the red highlight, but gives the same error message when I try so save the "Post" Event. Using Windows 10 Home.
Can you confirm the steps you're taking to get it to work?
Update: I have a potential hotfix for this for Beta 2, based on this web page: HTML5 input type=number and decimals/floats in Chrome | Isotoma: Our blog
It's strange I don't have the error message, but maybe changing the step to "any" will fix it for you.
Ahh. That works, yes. :)
Edit: Well, I thought it did. It said it was saved successfully when I modified those values in Chrome, but no events appear in Event management. Not even the default "Adjust" one. I might have to reinstall this again.
Anything in the server error log?
Nothing that seems related. I just uninstalled the add-on completely and then reinstalled. It will let me create Events successfully, but not show them to me. If I look in phpMyAdmin, I can see the created events are there.
Should be resolved now, I edited the file to fix the display issue and also added the "any" step so you should be able to edit the events properly now.
Hello kbryant414,
4.67 star(s) 6 ratings
