Yes, I mean the edit user. Thanks for confirming its OK, I didn't remember it being like that.Depends where exactly in the AdminCP you're referring to, but if you mean the edit user screen, then yes.
Currencies are stored with 8 decimals in the database, since a hard-coded amount of decimals will allow me to use data types that do not suffer from floating point rounding errors.
