bszopi
Former Developer
vBSlider v1.0.0 [BETA] ready for purchase.
Please note that no Lite version is available yet.
Please also note that it is not compatible with vBulletin 3.8.x.
We will make a Lite version when the Gold version is released.
Highlights
vBSlider is a professional slider mod, allowing administrators to show the latest threads, articles, and custom-defined content in a jQuery based slider.
Complete Feature List
General Settings
ACP Menu
CMS Options
CMS Widget
Custom Content Entry
Custom Content Listing
Forum Options
Forum Home Widget
General Options
Discuss this news here.
Highlights
General Settings
- Option to display version number in widget footer (not overall footer)
- Option to remove the DBT branding, if you purchased a branding free key for the product
- Option to not load jQuery, if it is already being called by another modification
- Option to select which version of jQuery to load
- Option to select how long each content item displays before transitioning to the next slide
- Option to pick the location inside the slider for the content
- Option to pick the text alignment of the content
- Option to provide a link to a default image for content items that do not have an associated image (a default DragonByte Tech image is provided)
- Option to select how many articles from the CMS you want to display
- Option to select how many threads from the forum you want to display
- Option to select which forums you want to include/exclude from the slider
- Option to select how many custom content items you want to display
- Option to select how many characters of the content item you want to display
- Option to enable or disable the widget on Forum Home
- Option to select location for the widget on Forum Home
- All of the other options listed for the CMS
- This gives you the ability to create your own content items to display to your users
- Ability to define a title and message for the content
- Ability to define a link if you want to provide additional information in a separate location
- Ability to define a link to an image for the content item
- Option to enable/disable on the CMS
- Option to enable/disable on Forum Home
- Option to enable/disable site wide
- All of the above options are definable for each custom content item
- Stylevars available for both the CMS and Forum versions, so that you can match each one to you specific design
- Ability to define a maximum width and height for the slider
- Ability to define the width of the content area when located on the left or right side
ACP Menu
CMS Options
CMS Widget
Forum Options
Forum Home Widget
General Options
