vB Awards and Activity Questions
Dirks
Hey guys, I'm considering changing from vBExperience by Phalanx to vB Awards and Activities primarily because of your vBcredits integration (also your ongoing product support is reassuring); however, before I do I have a few questions. I've scoured the available help documentation and these forums and didn't see any on point answers.
I run a creative writing RPG where players receive EXP for completing story threads. Right now, I patch the EXP as "custom points" into vBExperience rather than using the built in forum activity counter. It's a basic currency addition that vBcredits could easily handle (I use vBcredits lite for two other currencies on the site and it works perfectly); however, the members have grown fond of the EXP bar & built in level calculator that comes standard with vBExperience. I've also done some heavy template editing to make it ideal for the forum. I noticed that vB Awards and Activity has bars, but I can't tell if I can add custom points. Seeing the vB credits integration I assume I can, but I'm not sure. So, backstory aside, here are my questions:
1) Can I add custom points using vB A&A or vBcredits integration?
2) Can I set custom levels at certain point amounts?
3) Can I set custom awards that are not based on posts, reputation, likes, or any of the traditional auto awards? ((e.g. "Best Story of 2017", where I can choose an icon and have it appear in the postbit after assigning it to a player)).
Basically I want this in the postbit:
"User Name
EXP Bar w/ level & amount needed to level up (from vB A&A)
GP (from vBcredits)
AP (from vB credits)
Avatar
Awards (from vb A&A)"
And whenever I click the link on "EXP" "GP" & "AP" it opens up the handy transfer/add custom points function where my moderators do not have to open the modCP to add points (this is a standard feature w/ vBcredits).
Thanks in advance for the reply. Please let me know if you need me to be more clear.
Edit: It occurred to me that a picture might be useful. This is what I have now. I'm hoping I can keep it all w/ vB activity & awards. You can see that I can't click the EXP to add custom points, but I can click GP & AP using vBcredits.
Unfortunately you won't be able to achieve what you're looking for with vBActivity - the points system integration was designed to go the other way, e.g. spend vBActivity points without reducing your level, not add to your vBActivity level :(
The only thing you can actually do in vBActivity that suits your needs is #3, awards are not tied to any of the activity criteria (those are Achievements).
Sorry I couldn't bring better news :(
Hello Dirks,
