Bug Top submenu problem
rotor
Below is graphic of problem
If I open up the Link Directory (vbalinksdirectory) the sub menu for the Gallery opens and blocks out the Links submenus as per the att img
Of course if I disable the Gallery I dont have this problem in the Links Directory. Could be vBlinksDirectory or DB Gallery - not sure which one is causing this.
Both the Gallery and Links both add a link to the menu automatically and dont appear in the Navigation Manager.
Have you had this problem before - if so Is there a fix?
What happens if you click the Gallery menu entry, does the Link Directory subnav also show up then?
If I click on the Gallery button it only only shows the Gallery sub menu.
If I click on the Link button then the sub menu has both the sub menus - link and gallery mixed in and unreadable
i've left it up on the site if you want to look at it
I've added a potential hotfix for this to /dbtech/gallery/hooks/navigation_tab_complete.php for the latest version (v1.3.2 PL1). Could you please re-download the mod and re-upload that file and see if this works for you?
Additionally, I detected several problems with the Lite version of vBCredits, could you please also re-download v2.1.1 PL2 and re-upload all files from that product? You won't need to re-import the product XML file.
Menu item isnt showing after uploading that file.
I am also having a problem setting any permissions other than "Is Admin" - that is the only option as far as I can see in group permissions, and the menu item doesnt show for anyone but admin?
Update: This has now been fixed permanently @ your site and in the release product, thanks :)
Hello rotor,
Legacy DragonByte Gallery
