Bug system offline
m7shsh
Hello
the plugin showing showing System Status Offline
when I go here in Genral sitting
Enable Modification
From time to time, you may want to turn the modification off to the public while you perform maintenance, update versions, etc.
when I change it to yes or No
It give me this "Nothing to Do"
Help me to make the plugin run
Thanks
You need to also select a caching mechanism. If you leave it on None, the system will be offline.
Done
I've changed the URL formats around in such a way that should resolve any issues for you @ your site :)
