Thank you for replying. Ive disabled that addon and its still slow.This is a compatibility issue with the "[XFA] CustomUsernameIcons" mod. It does not cache permissions correctly, and causes 25 more queries than needed.
Ive installed slow query logging.Then you need to enable slow query logging and observe the log after a while.
Just checked and it's not enabled.Do you have the "Force formatting" setting enabled?
I created a copy of my forum to try find the problem. Ive removed items one by one and checked the speed.In that case there's nothing more that can be done unless the slow query log comes back with something related to this add-on. None of the queries in your .txt file were slow enough to cause 1.4 seconds worth of delays.
SELECT cache_value
FROM xf_permission_cache_content
WHERE permission_combination_id = ?
AND content_type = ?
AND content_id = ?
Params: 457, dbtech_shop_item, 3
Run Time: 0.000287
EXPLAIN would say 0.0002 seconds, not 0.5002 seconds.Nope all on same server. I don't know if its the more popular the item is, the more effect it has on index.php, or if i continue adding its going to get slower and slower.Do you have a separate web and database server?
Found the issue.Do you use custom permissions for your items?
Hope this helps i cant do anymore:Sorry I'm not sure what exactly you're saying, can you clarify please?
Are you saying the issue is in the "Usergroup Permissions" item?
I don't understand what this means. Can you please take screenshots of the item configuration?Usergroup Permissions (Yes / No)
(can bank) 8 purchase 1 active
(can steal) 7 purchase 1 active
Removed:I don't understand what this means. Can you please take screenshots of the item configuration?
