Bug several problems with
We have several problems with this AddOn.
Manage Forums: In the ACP-->DBTech - User Tagging-->Manage Forums i can untick several forum, but after i cklick "save", all forums are marked again.
I can use mention tu a usergroup like usergroupA. Sometimes it works, but most it does not. After i post the posting, the usergrou@"-part is not in the posting. Sometimes its in the posting, but without a funktion, only as normal words. Same with Hash Tags. Sometimes it works, but mostly it works not.
And one question: If i have a user (primary usergroup is "registered users", secondary usergroup is "adminA") and i deactivate the AddOn in "registered user"-group settings, the user can use the AddOn? Thats my plan. I want the AddOn only for the intern forums for admins, not for normal users.
thx in advance
regards
René
This is not a bug. You need to set max_input_vars to 100000 or higher in php.ini to be safe.
This can happen if too many users are in that group, or if the group does not receive user group mentions.
In vBulletin, "Yes" overrides "No", so if a user is a member of two groups, one of which has permission, then they will have permission.
First problem with max_input_vars=100000 solved, thx.
But mention to a usergroup dont work. If i mention "@groupA" , in the posting i see then "@myusername". I test it with several usergroups. In that groups are ~10-25 members.
Sorry, I'm not sure I fully understand. If you mention a user group, that mention (e.g. "@groupA") will be transformed into the list of members in that group, who will then be notified.
If this is what you are reporting, that is working as intended.
Then it is possible that you have either set a mention limit of 1 members per post, or the other 9 members have opted out of receiving mentions.
"Mentions at post" is set to "0".
I can Mention a Member of "groupA" directly, but if i mention "@groupA" only @myusername was shown in the posting.
Perhaps that user is the only user whose primary user group is the group you're trying to mention?
Before we do that, one more insight, maybe that helps with the error search:
If i in that group i try to mention, in the posting appear "@myusername" instead of all the usernames of that group. If i´m not in the group i try to mention, in the posting appear nothing. If i only type usergroupB, i´m not in that group and click sent, then vB says, that the posting is empty and i must enter at least at one letter. If i post the following:
usergroupB
qwerty
and i´m not in usergroupB in the posting only "qwerty" appear.
It works now. Thx for your help. First i used the lite version of the plugin. I overwrite it with the pro version, that was the problem. Now i delete all the files from pro and lite an reupload the files again only from pro version. Now it works.
We have found out that if multiple groups are mentioned only the last group will "expanded" and mentioned all other groups are not recognized.
Example:
@GroupA
@GroupB
@GroupC
Will result in the post as:
@GroupA
@GroupB
@Member1OfGroupC @Member2OfGroupC @Member3OfGroupC
Does this work as expected? Or is it possible to mention multiple groups at once?
Okay, thanks for your anwser.
I have found a workaround for this. So if you want to mention all members of 3 groups you have to save the post 3 times. Only the last group in the list will always expanded. But this works only if no @member mentions are in the same row as the @group mention tag.
Maybe you could fix/support that in the future.
Thank you very much for the support.
Hello Virtual Racing,
Legacy Advanced User Tagging
