Bug Removing Currency Crashed Entire Site and Admin CP
Cadbberry
During the holidays we created a new, temporary currency called Candy Points. Today, 1/10, we removed Candy Points and had a massive error occur. The entirety of Lake Valor because Errored and did not allow people to sign in, later on, it now shows that the website had an error occur with a white screen. When trying to access the Admin CP, all you can see is a blue screen with Xenoforo's logo and a list of errors which I have included in a screencap. We have been attempting to fix it since it has occurred but without being able to access the Admin CP we are at a loss of what to do. If you could please help us fix this error since it was the deletion of the currency that triggered it, that would be lovely.
Thank you,
Cadbberry
Yes, if multiple mods tried to access the currency then deleting it would cause that issue, that is to be expected.
You need to disable event listeners via config.php and remove this other currency from any other modification, or re-create it exactly as it was.
Hello Cadbberry,
4.67 star(s) 6 ratings
