Bug Privacy Options
drgoo1
under a new install, privacy options ser under user control panel are not working well (tested with mentions and quotes).
more details:
with only quotes and mentions enabled, under control panel, there are 2 privacy options:
dbtech_usertag_mentions
dbtech_usertag_tags (should be quotes)
And setting options doesn't work well (All, anyone...)
What do you mean by "doesn't work well"? Can you please describe what is happening, and what you expect to happen?
And I think problem is that I really don't set quotes privacy option, because is not available in control panel. Option in control panel is replaced by user tags (should not be there because is globally disabled).
I set mentions and quotes privacy setting to [anybody], logout, and can see quotes tab with quotes.
If the privacy setting is set to "Anybody", then it's working as intended that they see the tab when they log out.
I have resolved the issue that caused that to happen, if you re-download v3.2.2 PL1 and re-upload the files this should now be resolved :)
Thank you for letting me know :)
If you have any further issues or problems, please feel free to start a new support ticket. Thanks!
Legacy Advanced User Tagging
