This means you are browsing your site from the http version but your forum URL is https, or vice versa. You should update your forum URL to always use https, and apply .htaccess changes to redirect visitors to the https version.Appears to be working on Internet Explorer. Google Chrome it won't and I have to allow secure content to allow it to work?
I am using HTTPS for everything..... its this script trying to load thats making it appear as HTTP.This means you are browsing your site from the http version but your forum URL is https, or vice versa. You should update your forum URL to always use https, and apply .htaccess changes to redirect visitors to the https version.
Then your forum URL is set to http since this mod is 100% compatible with HTTPS.I am using HTTPS for everything..... its this script trying to load thats making it appear as HTTP.
Where do I change the forum to https? cause the site name / url is set to https://ihpk.netThen your forum URL is set to http since this mod is 100% compatible with HTTPS.
I have done all this... my shouts.... can you answer me pls?You can set BBCode permissions in the Instance Management screen.
Also make sure that all BBCode types except for HTML is enabled in non-forum areas when you go to the BB Code Options in vBulletin.I have done all this... my shouts.... can you answer me pls?
is there a way to make the [post=5445] [/post] work?
Why will the website not work? the shout box only works if i allow blocked content.
None of the shouts are hyper linked to the post either?
I see, sorry but that is not supported, I won't be able to assist with that unfortunatelySir I imported the shouts from an old shout box system into the dbtech vb shout tables
that's why i provided you with a .csv file.
Because there's no official importers into the Shoutbox. If we had provided an official importer, and imported shouts were not parsed, then that would be a different matter.How is it not supported?
There is no such parser in the product.Dude im asking you if you can run some sort of parser... to update the shouts
Because if I took days out of my schedule to complete custom work for free, I would be homeless. What you are asking is not a feature of the mod, and as such the only way I could help you would be if I coded it as a custom project, which would take time to complete.Why is your support so limited?
I have answered this, in more than one post. You need to set your BB Code options like this:You are NOT answering my question. WHY ARE THE SHOUT BOX REPLIES TO POSTS OR CREATION OF POSTS NOT CLICKABLE?!!!
Is your user a member of more than one user group?Another thing you "anti idle" doesn't work either.
I'm an admin and i've flagged myself exempt from going idle
still goes idle.
