Legacy Keywords and Descriptions for Forums
Mick
Hi,
I really like the way that I can edit threads to have my own Keywords and Descriptions for individual threads.
I wondered if you could add the ability to have your own keywords and descriptions on a per forum basis?
Is this something that is already possible? have I missed something?
Thanks for looking
Mick
Hi Fillip H.,
I have edited one of my forums here.
https://www.digitalworldz.co.uk/satellite-forums-539/
These are the keywords:
Digitalworldz, Satellite Forums, Satellite, forums, Dreambox, Technomate, Receivers, plugins, vu+, help, support, enigma, discussion, topics, emus, cams, shares, card, sky, uk, dish, linux, football, fixtures, feeds, astra, downloads, sat, boxes.
But when I view source they are not there?
view-source:https://www.digitalworldz.co.uk/satellite-forums-539/
Mick
This should now be resolved, if you re-download v1.3.2 and re-upload /dbtech/dbseo/includes/class_core.php :)
HI Fillip H.,
I can only get 9 keywords to show:
It cuts it off here:
Is there a set limit of 9 keywords or characters?
Regards
Mick
That is for the TITLE and the Description
I was talking about keywords:
and this is 98 anyway not 255?
Regards
Mick
Hmm, I'm unable to replicate any cut-off issues, I can save the full list of keywords you posted without issue. What's the character set in your database?
Thanks for getting back to me Fillip H.,
Can you jog my memory what is the command for that in ssh mysql...
Cheers
Mick
Thank you
See below
| Field                            | Type                           | Collation         | Null | Key | Default  | Extra          | Privileges                      | Comment |
| forumid                          | smallint(5) unsigned           | NULL              | NO   | PRI | NULL     | auto_increment | select,insert,update,references |         |
| styleid                          | smallint(5) unsigned           | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| title                            | varchar(100)                   | latin1_swedish_ci | NO   |     |          |                | select,insert,update,references |         |
| title_clean                      | varchar(100)                   | latin1_swedish_ci | NO   |     |          |                | select,insert,update,references |         |
| description                      | text                           | latin1_swedish_ci | YES  |     | NULL     |                | select,insert,update,references |         |
| description_clean                | text                           | latin1_swedish_ci | YES  |     | NULL     |                | select,insert,update,references |         |
| options                          | int(10) unsigned               | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| displayorder                     | smallint(6)                    | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| replycount                       | int(10) unsigned               | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| lastpost                         | int(11)                        | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| lastposter                       | varchar(100)                   | latin1_swedish_ci | NO   |     |          |                | select,insert,update,references |         |
| lastthread                       | varchar(250)                   | latin1_swedish_ci | NO   |     |          |                | select,insert,update,references |         |
| lastthreadid                     | int(10) unsigned               | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| lasticonid                       | smallint(6)                    | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| threadcount                      | mediumint(8) unsigned          | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| daysprune                        | smallint(6)                    | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| newpostemail                     | text                           | latin1_swedish_ci | YES  |     | NULL     |                | select,insert,update,references |         |
| newthreademail                   | text                           | latin1_swedish_ci | YES  |     | NULL     |                | select,insert,update,references |         |
| parentid                         | smallint(6)                    | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| parentlist                       | varchar(250)                   | latin1_swedish_ci | NO   |     |          |                | select,insert,update,references |         |
| password                         | varchar(50)                    | latin1_swedish_ci | NO   |     |          |                | select,insert,update,references |         |
| link                             | varchar(200)                   | latin1_swedish_ci | NO   |     |          |                | select,insert,update,references |         |
| childlist                        | text                           | latin1_swedish_ci | YES  |     | NULL     |                | select,insert,update,references |         |
| importforumid                    | bigint(20)                     | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| importcategoryid                 | bigint(20)                     | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| lastpostid                       | int(10) unsigned               | NULL              | NO   |     | NULL     |                | select,insert,update,references |         |
| showprivate                      | tinyint(3) unsigned            | NULL              | NO   |     | NULL     |                | select,insert,update,references |         |
| defaultsortfield                 | varchar(50)                    | latin1_swedish_ci | NO   |     | lastpost |                | select,insert,update,references |         |
| defaultsortorder                 | enum('asc','desc')             | latin1_swedish_ci | NO   |     | desc     |                | select,insert,update,references |         |
| seo_videos_bar                   | set('enabled','disabled')      | latin1_swedish_ci | NO   |     | disabled |                | select,insert,update,references |         |
| seo_videos_bar_source            | set('google','youtube','both') | latin1_swedish_ci | NO   |     | both     |                | select,insert,update,references |         |
| seo_videos_bar_videos            | int(3)                         | NULL              | NO   |     | 4        |                | select,insert,update,references |         |
| lastprefixid                     | varchar(25)                    | latin1_swedish_ci | NO   |     |          |                | select,insert,update,references |         |
| imageprefix                      | varchar(100)                   | latin1_swedish_ci | NO   |     |          |                | select,insert,update,references |         |
| fbtarget_id                      | varchar(255)                   | latin1_swedish_ci | NO   |     |          |                | select,insert,update,references |         |
| fbuid                            | varchar(255)                   | latin1_swedish_ci | NO   |     |          |                | select,insert,update,references |         |
| fbtarget_id_permission_granted   | varchar(255)                   | latin1_swedish_ci | NO   |     |          |                | select,insert,update,references |         |
| vbseo_moderatepingbacks          | int(10) unsigned               | NULL              | NO   |     | 1        |                | select,insert,update,references |         |
| vbseo_moderatetrackbacks         | int(10) unsigned               | NULL              | NO   |     | 1        |                | select,insert,update,references |         |
| vbseo_moderaterefbacks           | int(10) unsigned               | NULL              | NO   |     | 1        |                | select,insert,update,references |         |
| lastposterid                     | int(10) unsigned               | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| vbseo_enable_likes               | int(10) unsigned               | NULL              | NO   |     | 1        |                | select,insert,update,references |         |
| dbtech_thanks_firstpostonly      | int(10) unsigned               | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| dbtech_vbanswers_solution        | int(10) unsigned               | NULL              | NO   |     | 20       |                | select,insert,update,references |         |
| dbtech_vbanswers_bestanswer      | int(10) unsigned               | NULL              | NO   |     | 10       |                | select,insert,update,references |         |
| dbtech_vbanswers_goodanswer      | int(10) unsigned               | NULL              | NO   |     | 5        |                | select,insert,update,references |         |
| dbtech_vbanswers_show            | tinyint(1) unsigned            | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| dbtech_usertag_enabletag         | tinyint(1) unsigned            | NULL              | NO   |     | 1        |                | select,insert,update,references |         |
| dbtech_usertag_enablemention     | tinyint(1) unsigned            | NULL              | NO   |     | 1        |                | select,insert,update,references |         |
| dbtech_usertag_enablequote       | tinyint(1) unsigned            | NULL              | NO   |     | 1        |                | select,insert,update,references |         |
| dbtech_usertag_enablehash        | tinyint(1) unsigned            | NULL              | NO   |     | 1        |                | select,insert,update,references |         |
| dbtech_thanks_disabledbuttons    | int(10) unsigned               | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| dbtech_thanks_hide_threshold     | int(10) unsigned               | NULL              | NO   |     | 10       |                | select,insert,update,references |         |
| forumiconimg                     | varchar(100)                   | latin1_swedish_ci | NO   |     |          |                | select,insert,update,references |         |
| forumiconimg_forum_width         | smallint(3) unsigned           | NULL              | NO   |     | 48       |                | select,insert,update,references |         |
| forumiconimg_forum_height        | smallint(3) unsigned           | NULL              | NO   |     | 48       |                | select,insert,update,references |         |
| excludable                       | int(10) unsigned               | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| dbtech_dbforms_enabledcategories | int(10) unsigned               | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
| dbtech_dbseo_keywords            | varchar(255)                   | latin1_swedish_ci | NO   |     |          |                | select,insert,update,references |         |
| dbtech_dbseo_description         | varchar(255)                   | latin1_swedish_ci | NO   |     |          |                | select,insert,update,references |         |
| dbtech_dbforms_defaultcategoryid | int(10) unsigned               | NULL              | NO   |     | 0        |                | select,insert,update,references |         |
61 rows in set (0.00 sec)
If that looks untidy check this image
Can you try manually setting the keywords in the DB and see if that works? You'll have to edit and save any random forum (except for the one you're editing) in order for the changes to take effect.
Legacy Keywords
