Hey all,
We're committed to keeping our modifications up to date with the rapid advancements in modification author tools for vBulletin 5 Connect, and to that end we're releasing InfoPanels v2.0.6 Alpha 7, available immediately for users running vBulletin 5.0.4 or higher.
This release focuses on compatibility with the new tools available to us in vB 5.0.4, which will let us easily generate new pages populated with modules on installation rather than requiring user action post-install.
Additionally, as the CSS of vBulletin is being improved upon, we're making any necessary changes to our products to stay up to date.
Lastly, any other bugs noticed during testing have been fixed.
If you like the product you can show your support by nominating it for Mod of the Month here: InfoPanels v2 (vB5) - vBulletin.org Forum, and also please rate it if you have the product installed.
Change: 5.0.4 is now the minimum required version
Change: Changed module wrapper to use the built-in template
Fix: Fixed various other CSS change issues
Fix: The avatar for the Welcome block is now the correct size
Fix: The Top X Stats now correctly displays the title / collapse object
Fix: The "Newest Replies" block now works as intended
Fix: Fixed the missing drop-down icons on the columns
As always, thank you for your continued support!
Discuss this news here.
