Bug Hashtags Not Working
Hi there,
First of all, to address the Forum Manager issue; Can you please check for this menu group: https://i.imgur.com/ukeSK9l.png
If you can't find it, please add yourself to Super Administrators in config.php or use your super admin to give your regular admins Can Administer User Tagging.
Once you've got access to that page, make sure the "Hashes" is checked for every forum you wish to enable it in.
In the vBulletin Options, check that the Hashes aren't checked in the Globally Disabled Features area.
Also, make sure you've definitely re-downloaded the Pro version when upgrading from Lite and re-uploaded all the Pro files.
Furthermore, check the usergroup permissions to make sure your user group(s) are set up to allow hash tags to be used.
If you can confirm that all of those things are configured correctly and it still doesn't work, try disabling all other products leaving only AUT enabled.
If after all of that it STILL doesn't work, feel free to PM me with an FTP and AdminCP account and I'll look into it :)
Ok, I added myself to the Superadmin group in the config.php and I can now see the menu for AUT.
Here are screenshots of my settings. It looks like everything is setup right for hashtags.
I never installed the lite version, so I don't have to worry about uploading after that. I just purchased the pro version and uploaded that.
Are there any other settings I am missing?
Hello chris27,
Legacy Advanced User Tagging
