Bug Godaddy / Scripting Error
P1admin
updating my Cpanel information,
...during the process of this as well as updating with Xenforo.com - main license - anyways...
here is what we did and here is what happened...
goddady.... sent this over... I hope this helps...
regardless...
for whatever reason - something broke - so we are in ,the process of i guess starting over...
anyways..., input would be appreciated as - I told godaddy, updating my cpanel to accept a change... should not break XF or an Addon...
You: chaning the pathing should not break the forum software(Xenforo.com) or cPanel(godaddy)
15:32, Feb 22
15:33, Feb 22
HARLEEN DHIMAN: Sure! let me help you to understand it.
15:33, Feb 22
15:34, Feb 22
You: ok
15:34, Feb 22
15:38, Feb 22
HARLEEN DHIMAN: Please bear with me.
15:38, Feb 22
15:38, Feb 22
You: no problem
15:38, Feb 22
15:38, Feb 22
HARLEEN DHIMAN: Thankyou.
15:38, Feb 22
15:52, Feb 22
HARLEEN DHIMAN: You will need to review the error_logs and can start from there to further investigate on the issue. Error log shows: [22-Feb-2020 21:36:07 UTC] PHP Fatal error: Access level to DBTech\Credits\XF\Entity\User::_postSave() must be public (as in class ThemeHouse\UserNameChange\XF\Entity\User) in /home/k435mulowfwu/public_html/src/addons/DBTech/Credits/XF/Entity/User.php on line 206 [22-Feb-2020 21:36:30 UTC] PHP Fatal error: Access level to DBTech\Credits\XF\Entity\User::_postSave() must be public (as in class ThemeHouse\UserNameChange\XF\Entity\User) in /home/k435mulowfwu/public_html/src/addons/DBTech/Credits/XF/Entity/User.php on line 206 [22-Feb-2020 21:40:02 UTC] PHP Fatal error: Access level to DBTech\Credits\XF\Entity\User::_postSave() must be public (as in class ThemeHouse\UserNameChange\XF\Entity\User) in /home/k435mulowfwu/public_html/src/addons/DBTech/Credits/XF/Entity/User.php on line 206 This is already out of our scope of support. You will need to fix this as there's no issue with the server/host. If you have a backup copy of your site which is working then you can upload those files.
15:52, Feb 22
15:53, Feb 22
You: ok - i'll copy pate thanks
This is a bug with the ThemeHouse/UserNameChange addon. Please post this in their support ticket system instead.
You can give them this information:
XF\Entity\User::_postSave() should be protected, not public.
Hello @P1admin,
Hello @P1admin,
4.67 star(s) 6 ratings
