Bug Job DBTech\Credits\Job\DailyCredits: Please enter a number that is no more than 9223372036854775807.
Peter76
I saw this server error. Any ideas?
  • XF\PrintableException: Job DBTech\Credits\Job\DailyCredits: Please enter a number that is no more than 9223372036854775807.
  • src/XF/Mvc/Entity/Entity.php:1270
  • Generated by: Unknown account
  • Jul 8, 2025 at 9:03 PM
Stack trace​
#0 src/addons/DBTech/Credits/EventTrigger/AbstractHandler.php(610): XF\Mvc\Entity\Entity->save(true, false)
#1 src/addons/DBTech/Credits/EventTrigger/AbstractHandler.php(448): DBTech\Credits\EventTrigger\AbstractHandler->trigger(Object(XFMG\XF\Entity\User), 129, false, Object(ArrayObject))
#2 src/addons/DBTech/Credits/Job/DailyCredits.php(143): DBTech\Credits\EventTrigger\AbstractHandler->apply(129, Array, Object(XFMG\XF\Entity\User))
#3 src/XF/Job/AbstractRebuildJob.php(42): DBTech\Credits\Job\DailyCredits->rebuildById(129)
#4 src/XF/Job/Manager.php(275): XF\Job\AbstractRebuildJob->run(3.45734)
#5 src/XF/Job/Manager.php(205): XF\Job\Manager->runJobInternal(Array, 3.45734)
#6 src/XF/Job/Manager.php(89): XF\Job\Manager->runJobEntry(Array, 3.45734)
#7 job.php(46): XF\Job\Manager->runQueue(false, 8)
#8 {main}
Request state​
array(4) {
["url"] => string(8) "/job.php"
["referrer"] => string(47) "https://www.welovetheeighties.com/help/cookies/"
["_GET"] => array(0) {
["_POST"] => array(0) {
You will need to adjust your events and currencies to not have such insanely inflated numbers. The database cannot handle numbers this large.
This is not a bug.
Hello @Peter76,
This is not a bug.
Hmmm do you mean currency taxation? Im looking at my settings but I dont see anything crazy. Im not sure exactly what to look for to adjust. thanks
I mean your entire currency configuration, the only way taxation or paycheck would produce such insane numbers is if you award let's say 5 billion points per post, or something else insane. You should change all your currency values to be more human readable, and then go to Tools -> Rebuild caches and reset all currencies to 0.
It is literally impossible for me to add support for numbers that are bigger than the maximum number possible to store in a database.
That's the thing i don't have anything like that. Those are my events and far below is my credit setup. I don't see anything out of the ordinary unless I'm missing something.
Screenshot 2025-07-21 091206.webpScreenshot 2025-07-21 091217.webpScreenshot 2025-07-21 091228.webp
If you go to the Richest Users tab in the front-end, do you see user ID 129 with inflated values?
You can exclude the bot user from events by putting it in a user group with “Trigger Events” set to “Never”
Hello @Peter76,
Hello @Peter76,
4.67 star(s) 6 ratings
