Question Exchanging between credits
Senkusha
I have two currencies defined. I'd like to offer a way for my users to convert one currency (earned) into the the other (not earned). Would this be done through the Shop, or is there an inherent process to do this within the Credits extension?
This can be done via Credits; you’d need to setup a Transfer event I believe it’s called. You’ll need one for each currency. The base currency should have an exchange rate of 1.
The event options should explain it better than I can at the moment as I’m not in the office.
Okay, I found the Event (Transfer), but for Currency, which do I select the Originating (Lumina) or the Destination (Staryen). Also, where to do I initiate the transfer? I've looked in the Credits tab and in my Profile. I not seeing the option.
Sorry, I don't understand this question.
Click on any currency amount and in the popup choose the Transfer tab.
It will not show up until at least two currencies have a Transfer event.
Hello @Senkusha,
5.00 star(s) 5 ratings
