Bug Errors trying to moderate posts - deleting and validating
subaruclub
Just installed the latest version.
I am getting the following error when trying to validate or delete moderated posts:
Fatal error: require(): Failed opening required '/home/subaru/public_html/forums/dbtech/dbseo_pro/hooks/forumdata_start.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/subaru/public_html/forums/includes/class_dm_forum.php(123) : eval()'d code on line 1
D
Please upload all files that came with the new version before importing the XML file and attempting to use your forum as normal.
Something that sort of stands out is that I am using the lite version and the path in the error says pro
Is this something significant
Yup... that's the issue.
There is no "dbseo_pro" directory
Looks like the lite version has the wrong paths in the code.
D.
Ah, I see. I've made changes to the XML files that should resolve this, if you re-download v1.3.2 and re-import the XML file this should be resolved :)
