Bug Disable per forums not working
Norman
If I go to Forum Manager and I check some checkboxes... when I save they aren't saved. They return all unchecked.
Hi Norman,
This can happen if you have a very large amount of forums and/or usergroups, and your max_input_vars in php.ini is left at the default value of 1000. If this is the case, PHP will cancel the input.
Could you please double-check that variable and make sure it's set to a much higher number, such as 100000 ?
Thanks!
Hello Norman,
