Question Description larger than 200 characters
eurekka
How can i make description larger than 200 characters?
It is capped to 200
thanks
That is not something we would be able to assist with unfortunately. You can find the setting name by viewing the source of the settings page, then search the files for the references to that name.
Detailed instructions on how to modify this or how to modify the setting is not going to be possible unfortunately.
Just asking where is the template I need to change. I'll do the rest
My descriptions are too short and Google can show show over 300.
Be nice
It's not a template. I gave you the instructions for how to find the place in the code :)
I'm not sure what your post is trying to say. The setting is called dbtech_dbseo_metakeyword_length and that is the string you need to search all files for.
I really don't understand why not giving support to customers with files that need to be changed when Google accept 300 char. in description. I dont see the point of this
If I gave step-by-step instructions every time someone asked us to customise our products, for free, then I would never get any work done.
If you want, I can change this ticket to a feature request to have the limit increased instead.
What doed that imply?
I think the string is setting_dbtech_dbseo_metadescription_length_desc
what is a feature request and how does it work?
A feature request is a thread that requests a new feature be added to a product, or an existing feature to be changed. There’s no guarantees it will be implemented, or the time frame, but it lets me see which features customers want.
Up to you.
I still don't understand why no support given on this or a simple post explaining the way to change it
It users had the option to change description lenght would be much easier for everybody.
Hello @eurekka,
