Question Display thumbnails
anil
does the store only display the 200x200 icon image as the main display, or is there a way I can use the image inside my description as the main display? because the quality for the icon display isnt great.
Hi there,
You can set the product icon's dimensions via the "Maximum product icon dimensions" setting in the options for this add-on.
Hi there,
is there another way to get the full quality? because the icon images I upload are the full quality, but the display for the store is blurry quality. changing the dimensions just makes the images bigger and making the storefront looks goofy.
Check your attachment upload quality settings, it’s possible those thumbnail settings are affecting this.
Hello @anil,
Hello @anil,
4.86 star(s) 7 ratings
