Eden
I would like to contact you because your product works more like before.
Since I reinstall it, it does not seem to work. I still have about ten lines of codes at the bottom of the page.
As I bought many of your products, you can imagine how many lines I have and it is not at all aesthetic.
I would have liked to reduce the size of copyright footer, but unfortunately, your mod does not seem to work properly.
Moreover, I noticed that your product contains only one xml file, the "upload" file is empty. But that's probably normal.
It's just that I expected that this file is not totally empty ...
In any case, thank you in advance for your help!
