Hey all,
We're releasing Advanced Post Thanks / Like v3.1.5 in order to address an important issue: vB Optimise integration! With this version you can save nearly half a dozen queries per page load on the Member Profile page alone, as well as an additional two queries per page load on the "Hottest Threads / Posts" page.
Not only that, but we're also adding the ability to disable "buttons clicked" from member profiles. This is a feature a lot of you have asked about, it lets you ensure only "Thanks" (and other button clicks) that the user received, rather than both given and received.
If you like the product you can show your support by nominating it for mod of the month here: Advanced Post Thanks / Like v3 (vB4) - vBulletin.org Forum or here: Advanced Post Thanks / Like v3 (vB3) - vBulletin.org Forum, and also please rate it to help cancel out the users who 1 star our mods.
Complete Change Log
vB Optimise Integration
Profile Settings
Bugfixes
As always, thank you for your continued support
Discuss this news here.
Complete Change Log
- Support for vB Optimise to cache the Hottest Statistics page (Cached queries: 2 per button)
- Support for vB Optimise to cache the Member Profile tab (Cached queries: 5)
- Moved the vB Optimise setting for caching Show Thread queries to the vB Optimise product
Profile Settings
- (Pro) Added option to disable the "button clicks given" from member profiles
Bugfixes
- Deleted threads / posts should no longer show up in the "Hottest Threads / Posts" statistics page
