Hey all,
Just a quick update to address some small issues that only affect vBulletin 4.x. If you're running vBulletin 3.x, you don't need to apply this update![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
Advanced Post Thanks / Like v3.0.0 (Beta 5):
Fix: (vB4) Links to posts in the Profile tab were incorrect for certain Friendly URL types.
Fix: (vB4) Sidebar block would cause error on Block Type reload. -Note: You will need to edit and save any Sidebar blocks you have configured for APTL before the error goes away! If you also have the Pro version of our AUT product, a similar fix has been released there.-
Thank you for your continued support![Smile :) :)](https://cdn.jsdelivr.net/joypixels/assets/8.0/png/unicode/64/1f642.png)
Discuss this news here.
