Bug Adjust isn't working?
dfarmer2001
I am attempting to add some additional forum currency to a specific member on my forum, however, when I attempt to adjust the currency for the member whether it be through the quick adjust, or through the adminCP, it doesn't work. The maximum earnings per day is at $1.05 Cash, and I assume this is why it won't allow me to adjust the member's currency because I'm trying to adjust more than the daily limit permits.
Is there a way around this? How can I fix this without altering the daily limit?
Currently this is not possible as all events are subject to the limit. I'll keep this open to see if I can exclude Adjust from that limit in the future.
I have a couple of other questions in regard to this.
1. If I were to enable transfers between members, would it make a difference, or would the system still block off the transfers that are over the daily limit?
2. If I were to create a separate currency and allow the exchange/transfer from this currency to the main currency, would the issue still persist with the daily limit?
It may not make a difference with the daily limit either way, but I figured it wouldn't hurt to ask and be sure.
Thank you in advance! :)
I believe the limit is global for all transactions.
Transferring in would still be subject to the limit unfortunately.
Hello @dfarmer2001,
4.67 star(s) 6 ratings
