Question a kind of prune question...
Valcav
Hi,
this may sound crazy, so, I'm just asking if it is possible,
when executing the prune command, that the "Notifications", "System Messages", "Shout Reports" aren't getting pruned but the rest is?.?.?.
Again, I'm just asking if it is possible...
Or a delete option? to select which shouts/notifications/... are getting deleted or pruned?
Friendly greetings,
Valcav
Notifications generated prior to 5.4.0 will not be pruned, due to the way they are stored being incompatible with the pruning method. The only way to delete those would be to double-click them and delete them that way.
Thanks for the fast respons,
but maybe I wasn't clear enough on my kind of question...
I was actually asking if it is possible when I do the prune command, to select (or something) what is getting (needs to be) pruned...
For instance when I do prune, I want to only prune self made shouts of all persons... while I want that the rest ("System Messages", "Shout Reports") aren't getting pruned...
I hope this is more clear now...
Friendly greetings,
Valcav
Question Weird
