Bug After upgrading to 1.3.1 Error in CMS pagination
hola
I have upgraded to 1.3.1 and I have an error in CMS main section pagination that is not being rewritten.
when you go to page 3, the URL is:
domain.com/index.php?page=3
In secondary CMS sections it is working fine. This is the rule:
[section_title]-s[section_id]-pag[page].html
Please help, in the past I had similar problem and you solved,
Thanks,
Go to your CMS URLs and make sure every item there has a selection, there was a URL format change due to confusion between categories and sections that necessitated a change that may invalidate certain configurations.
I have all with a selection. Only
CMS Home URL is blank (because it is the index)
(Pro) Custom CMS Home URL is /
All the other configs are correctly configured in the panel.
The problem is that you have somehow managed to force vBulletin into using index.php instead of content.php as the base URL of your CMS scripts. This is preventing the DBSEO rewrites from working as intended.
I have tried to undo this on your site, but I cannot figure out how to do it. Please undo this, and allow DBSEO to handle the /content.php to / rewrite, then the pagination should work as intended :)
