Hey all,
For those of you who are testing out the Beta version of vBulletin, I've released vBShout (vB5) v6.1.0 Alpha 2 and InfoPanels (vB5) v2.0.6 Alpha 4. Currently, it's only available from vBulletin.org - this is something that will change as more products are updated and we need to expand our testing base.
If you like the products, you can show your support by nominating them for Mod of the Month here: vBShout (vB5) or here: InfoPanels (vB5), and also please rate it to help cancel out the users who 1 star our mods. Thanks
The full changelogs are below:
Fix: Fixed an issue that could prevent the Shoutbox from loading on certain systems
Change: Compatible with Beta 14 and newer only!
Change: The copyright notice has moved to the new footer_copyright template hook
Change: Changed the way user info is fetched to be compatible with 3rd party addons
Change: Replaced calls to $vbphrase (legacy code) with the new vB_Phrase class
Fix: URLs would show replacement string text on AJAX refresh
Fix: Newest Replies block would return invalid data if the thread had no replies
Fix: Fixed an issue that could prevent the Top X Stats from loading on certain systems
Thanks for your continued support
Discuss this news here.
