Hey all,
Over the past week, a couple of bugs have been discovered in the Pro versions of vBShop and vB Optimise. For that reason, we're releasing vBShop v3.1.0 Hotfix #2 and vB Optimise v2.5.3 Hotfix #1.
vBShop v3.1.0 Hotfix #2:
(Pro) Fix: Members should no longer be able to leave feedback on transactions from their own shop
(Pro) Fix: Members should no longer receive feedback reminders on transactions from shops that have feedback turned off
vB Optimise v2.5.3 Hotfix #1:
(Pro) Fix: AdminCP permissions were not correctly applied to the CDN Settings in the navigation XML file
If you'd like to help us out, you can rate our threads on vbulletin.org
vBShop: [DBTech] vBShop v3 (vB4) - vBulletin.org Forum / [DBTech] vBShop v3 (vB3) - vBulletin.org Forum
vB Optimise: [DBTech] vB Optimise v2 (vB4) - vBulletin.org Forum / [DBTech] vB Optimise v2 (vB3) - vBulletin.org Forum
Your votes help us combat the 1-star trolls!
Thanks for your continued support
Discuss this news here.
