Well after some trying times, it has finally all come together, and I am happy to get this out to you guys.
This week it will be Pro only, if all goes well it will be released as Lite next week. You can get the new files by downloading vBNavTabs v1.2.0 from your customer area. Inside the download folder is another zip file vBNavTabs For vB 4.2 ONLY!!!.zip
Extract that and upload it to your server, then import the product. As always, thank you for the support!
You can read how to make droptabs here: http://www.dragonbyte-tech.com/f117/making-tab-drop-tab-vbnavtabs-vb4-2-a-7975/#post45137
Here is a run down of what is in the product.
Complete Feature List
Lite Features
Additional Pro Features
vB 4.2 Navigation Manager before install:
Navigation Manager after install of product:
Front end view:
Discuss this news here.
Lite Features
- Stylevars
- Has a stylevar to set the min width of popup boxes.
- Has a stylevar to set the padding around sublink items.
- General Settings
- Option to display the product version or not.
- Option to remove the Hivelocity branding link in the footer. (Lite)
- Option to enter a Branding Free key if you purchased one for the mod.
- Ability to show a Search Tab, works similar to the Global Search Box.
- Ability to set which usergroups can see the Search Tab.
- Ability to set the text color of the Search Tab.
- Option to have Drop Tabs open on hovering over them.
- Option to have Sublink Menus open on hovering over them.
- Add / Edit Tabs
- Ability to set the text color of the tab text.
- Ability to set which usergroups "Can" see the tab.
- Ability to set which usergroups "Can Not" see the tab.
- Ability to choose which styles the tab shows on.
- Ability to set Tab Target, four options on how you want tabs to be opened in a web browser.
- Ability to add a title to the tab, which users see when the hover over the tab.
- Ability to choose which menu to act as the dropdown for the tab, (editing tab only).
- Add / Edit Menus
- Ability to move the menu to a different parent tab, (editing menu only).
- Ability to set the text color of the menu text.
- Ability to set which usergroups "Can" see the menu.
- Ability to set which usergroups "Can Not" see the menu.
- Ability to choose which styles the menu shows on.
- Ability to add a title to the menu, which users see when the hover over the menu.
- Add / Edit Links
- Ability to move the link to a different parent tab, (editing link only).
- Ability to set the text color of the link text.
- Ability to set which usergroups "Can" see the link.
- Ability to set which usergroups "Can Not" see the link.
- Ability to choose which styles the link shows on.
- Ability to add a title to the link, which users see when the hover over the link.
- Stylevars
- Has a stylevar to add padding around the images.
- Has a stylevar to set the images directory, so you can use different images for items on different styles.
- General Settings
- Ability to hide the Global Search Box.
- Option to show a image on the Search Tab.
- Ability to easily change the image for the Search Tab.
- Select 1, 2, or 3 columns to show on usergroup selection area, when adding/editing items in the Navigation Manager useful for forums with alot of usergroups.
- Ability to add unlimited extra navbars to add the tabs to.
- Add / Edit Tabs
- Ability to set which navbar the item shows in.
- Ability to set a image to show on the tab.
- Ability to add rel="nofollow" to the tabs.
- Ability to have notes for the tab, viewable when you edit a tab.
- Add / Edit Menus
- Ability to set a image to show on the menu.
- Ability to add rel="nofollow" to the menu.
- Ability to have notes for the menu, viewable when you edit a menu.
- Add / Edit Links
- Ability to set a image to show on the link.
- Ability to add rel="nofollow" to the link.
- Ability to have notes for the link, viewable when you edit a link.
Front end view:
