Hey all,
We've recently discovered a few issues with the "Points Cache" features and turning off the "Points for Days Registered". Additionally, we've identified memory usage issues with the "Rebuild Points Cache" maintenance action. For this reason, we're releasing vBActivity & Awards v3.1.4 Patch Level 1 in order to address these issues.
If you like the product you can show your support by nominating it for mod of the month here: vBActivity & Awards v3 (vB4) - vBulletin.org Forum or here vBActivity & Awards v3 (vB3) - vBulletin.org Forum, and also please rate it to help cancel out the users who 1 star our mods.
Complete Change Log
Bugfixes
As always, thank you for your continued support
Discuss this news here.
Complete Change Log
Bugfixes
- The "Award Daily Points" script will now correctly reset its points caches if the "Points for Days Registered" is turned off
- The "Days Registered" criteria should now function correctly in all cases
- The "Days Since Last Post" criteria should now function correctly in all cases
- The "All Achievements" page will now check criteria with special calculations needed (such as "Days Registered" and "Days Since Last Post") correctly
- Recalculating points should now work more reliably for large boards (using the command line maintenance script may still be required)
