Fixed: A issue with false positives showing up when you clicked the link in the header if there were true "moderated posts".
Fixed: A issue with extra queries on the hidden posts page.
Changed: It will now get any previous posts hidden before that are not showing on the view hidden posts page.
Changed: The hidden posts table to be wider.
Added: A display options table so you have more options to display the posts on the hidden posts page.
Added: A stylevar so you can have different color backgrounds for moderated / hidden posts for each style.
NOTE: If you have alot of posts in moderation, it will take some time for the product to import, due to the fact it has to check each record and see if it should be a hidden post or a true moderated post. I would suggest making sure you have no posts/threads awaiting moderation in the acp before upgrading.
To use the stylevar to change the background follow these steps.
In postbit_legacy find:
Change to:
Then add some CSS to additional.css like:
Then to set the background color go to stylevars, under DragonByteTechMods look for sohp_background and you can set the color there.
For those of you who had done the background color before, simply change what you put in the addditional.css with what is posted here.
For Translation Purposes:
Added: The phrase, dbtech_staffonlyhiddenposts_sohp_posts
Added: The phrase, dbtech_staffonlyhiddenposts_thread
Added: The phrase, dbtech_staffonlyhiddenposts_hidden_by
Added: The phrase, dbtech_staffonlyhiddenposts_forum
Added: The phrase, dbtech_staffonlyhiddenposts_replies
Added: The phrase, dbtech_staffonlyhiddenposts_views
Added: The phrase, dbtech_staffonlyhiddenposts_moderation_tools
Added: The phrase, dbtech_staffonlyhiddenposts_showing_messages_x_to_y_of_z
Added: The phrase, dbtech_staffonlyhiddenposts_icon_legend
Added: The phrase, dbtech_staffonlyhiddenposts_new_posts
Added: The phrase, dbtech_staffonlyhiddenposts_no_new_posts
Added: The phrase, dbtech_staffonlyhiddenposts_no_hidden_posts
Added: The phrase, dbtech_staffonlyhiddenposts_try_controls_below_for_older_posts
Added: The phrase, dbtech_staffonlyhiddenposts_display_options
Added: The phrase, dbtech_staffonlyhiddenposts_show_results_deleted_within
Added: The phrase, dbtech_staffonlyhiddenposts_show_results_hidden_within
Added: The phrase, dbtech_staffonlyhiddenposts_last_day
Added: The phrase, dbtech_staffonlyhiddenposts_last_2_days
Added: The phrase, dbtech_staffonlyhiddenposts_last_week
Added: The phrase, dbtech_staffonlyhiddenposts_last_10_days
Added: The phrase, dbtech_staffonlyhiddenposts_last_2_weeks
Added: The phrase, dbtech_staffonlyhiddenposts_last_month
Added: The phrase, dbtech_staffonlyhiddenposts_last_45_days
Added: The phrase, dbtech_staffonlyhiddenposts_last_2_months
Added: The phrase, dbtech_staffonlyhiddenposts_last_75_days
Added: The phrase, dbtech_staffonlyhiddenposts_last_100_days
Added: The phrase, dbtech_staffonlyhiddenposts_last_year
Added: The phrase, dbtech_staffonlyhiddenposts_beginning
Added: The phrase, dbtech_staffonlyhiddenposts_select_daysprune_description
Added: The phrase, dbtech_staffonlyhiddenposts_sort_results_by
Added: The phrase, dbtech_staffonlyhiddenposts_title
Added: The phrase, dbtech_staffonlyhiddenposts_date
Added: The phrase, dbtech_staffonlyhiddenposts_sort_results_description
Added: The phrase, dbtech_staffonlyhiddenposts_all_forums
Added: The phrase, dbtech_staffonlyhiddenposts_select_forum_description
Added: The phrase, dbtech_staffonlyhiddenposts_order_results
Added: The phrase, dbtech_staffonlyhiddenposts_in_ascending_order
Added: The phrase, dbtech_staffonlyhiddenposts_in_descending_order
Added: The phrase, dbtech_staffonlyhiddenposts_order_results_description
Added: The phrase, dbtech_staffonlyhiddenposts_inline_mod
Added: The phrase, dbtech_staffonlyhiddenposts_select_all
Added: The phrase, dbtech_staffonlyhiddenposts_deselect_all
Added: The phrase, dbtech_staffonlyhiddenposts_invert_selection
Added: The phrase, dbtech_staffonlyhiddenposts_select_posts_with_attachments
Added: The phrase, dbtech_staffonlyhiddenposts_merge_posts
Added: The phrase, dbtech_staffonlyhiddenposts_move_posts
Added: The phrase, dbtech_staffonlyhiddenposts_delete_posts
Added: The phrase, dbtech_staffonlyhiddenposts_undelete_posts
Added: The phrase, dbtech_staffonlyhiddenposts_approve_posts
Added: The phrase, dbtech_staffonlyhiddenposts_view_selected_posts
Added: The phrase, dbtech_staffonlyhiddenposts_clear_post_list
Added: The phrase, dbtech_staffonlyhiddenposts_proceed
Added: The phrase, dbtech_staffonlyhiddenposts_full
Added: The phrase, dbtech_staffonlyhiddenposts_viewing
Added: The phrase, dbtech_staffonlyhiddenposts_display_timeframe
Added: The phrase, dbtech_staffonlyhiddenposts_display_by
Added: The phrase, dbtech_staffonlyhiddenposts_display_forum
Added: The phrase, dbtech_staffonlyhiddenposts_display_ascdesc
Added: The phrase, stylevar_sohp_background_description
Added: The phrase, stylevar_sohp_background_name
Discuss this news here.
HTML:
<div class="postbody">
Change to:
HTML:
<div class="postbody <vb:if condition="$show['moderated']">moderated</vb:if>">
HTML:
.postbitlegacy div.postbody.moderated {
background: {vb:stylevar sohp_background};
