Bug Shop username style different colors on forum index
db-fan22
the Shop username style is different colors on forum index, i waited several days because i thought maybe it was a cron,
but it never changes, the red is the style i have before, but does not update
i think its a bug,
8430
8431
This could be a caching issue, there is no bug here as the code being ran in both locations is identical.
what do you mean caching issue? i delete my browsing histroy and cache but problem still happens
how to clear xenforo cache?
Do you have any caching options enabled in config.php? Or installed any addon that caches the forum display?
i should of thought of disabling my add-ons first, you are so smart
i found the problem, the problem is the add-on "ads manager by siropu"
when i disable his add-on, everything works properly,
i will make ticket with him
his add-on enabled
8438
his add-on disabled
8437
siroup say there is no cache in his add-on, but he need to know how does the shop add-on add the style to the username
in technical explanation
I extend \XF\Template\Templater :: fnUsernameLink and add a style attribute like so:
if ($styleProps)
   $attributes['style'] = isset($attributes['style']) ?: '';
   $attributes['style'] .= implode('; ', $styleProps);
ok siropu say he cannot see problem in his add-on
i disabled his add-on again and enabled, and now i cannot reproduce the error, so he is right, his add-on is not causing problem, so it was my mistake, his add-on is not the problem
so i downloaded 4 different browsers, 3 browser have the same problem,
the only browser that works and changes the color right away is "brave browser", i dont know why the 3 other browsers are having this caching problem
firefox on left, brave on right
8445
edit, ok after 10 minutes, it change the color, and then it change back to before color,
i dont know why, it gives me many problems
i don't understand browser cache
Hello @21515,
Question Shop Icons
DragonByte Shop
5.00 star(s) 3 ratings
