Bug Points are not deducted after deleting a rating in XFRM
dritream
Hello. The question is explained in the topic.
When a review is deleted, the points remain. They are only removed if the review is permanently deleted by a moderator — meaning the event itself is completely removed, and logically the points are deducted because the event no longer exists.
However, if a user deletes their own review, the points are not deducted.
I tried to handle this using Event negation amount, but apparently this setting is not related to this behavior.
I think I’ve found why Credits does not deduct points when a user deletes their own XFRM review (soft delete), while it does deduct when a moderator permanently deletes it.
What’s happening
In XFRM, deleting a review as a user is a soft delete, implemented as an update:
• XFRM\Entity\ResourceRating::softDelete() sets rating_state = 'deleted' and calls save()
So this is a state change on update (visible → deleted), not a hard delete.
Your Credits integration for XFRM ratings is in:
DBTech/Credits/XFRM/Entity/ResourceRating.php
Currently it:
• applies points only on insert (_preSave/_postSave return early when $this->isUpdate())
• undoes points only on hard delete (_preDelete/_postDelete)
Because of the early return on update, Credits never sees the rating_state transition caused by soft delete, so points remain.
What I changed (and it works)
I modified DBTech/Credits/XFRM/Entity/ResourceRating.php to handle update state transitions similarly to how you handle posts in DBTech/Credits/XF/Entity/Post.php (using isStateChanged(..., 'visible')).
Specifically:
1. In both _preSave() and _postSave(), I removed the || $this->isUpdate() from the early return:
if (!$this->user_id || $this->isUpdate()) { return; }
if (!$this->user_id) { return; }
2. I added an update branch that detects:
$visibilityChange = $this->isStateChanged('rating_state', 'visible');
and then:
• if $visibilityChange == 'leave' (visible → deleted): call testUndo/undo for resourcerate and resourcerated
• if $visibilityChange == 'enter' (deleted → visible): call testApply/apply for the same handlers
Insert logic remains unchanged.
After this patch:
• creating a review grants points as before
• soft deleting a review by the author deducts points correctly
• undeleting restores the points
Hi,
Thank you for the detailed report, much appreciated! I've applied the changes as a hotfix to v6.1.3 as I'm currently working on a refactor aimed at improving UX surrounding event configuration, so it would take some time to release a new version with this fix included.
4.67 star(s) 6 ratings
