Question Per-Thread Management
sarahw
Hi there!
The documentation for the Pro version states: "Per-thread ability for administrators with the "Manager" permission to override forum / usergroup settings and either enable or disable automatic updates"
However, I can't seem to determine where to enable/disable auto updates for any given thread. I have set my Admin usergroup up as a manager.
Thank you, Fillip! I was looking for it in the Administrative dropdown itself.
Would you mind sending me a screenshot of what I should see now that I'm on the Edit screen? I can see in there that there are two Options, but something is wrong with my language tables, apparently, and I know there should be text next to the boxes, but it's missing:
(this has arisen for me a few times, so I know it's not the plugin or plugin installation ... but if I know what it SHOULD say, I'll either hard-code the phrase or just make a point of remembering).
Thanks for your help, and sorry for the hassle!
I think I found it in phrases --
Checkbox #1: Automatically Refresh Thread
Checkbox #2: Override Forum / Usergroup Automatic Update Permissions?
Is that right?
Right now, every thread I peeked in on had Box #1 checked, I assume because I have the plugin enabled forum-wide. However (according to the way I set it up), the auto-updates don't kick in until a thread has 30 posts.
What is the effect of checking box #2?
Thanks again for your help.
That's correct :)
Box 2 determines whether the usergroup permissions and the per-forum settings configured in the AdminCP are respected. If unticked, and the forum has auto-updates disabled, box 1 has no effect.
Legacy AJAX Threads
