Bug No thread Created, when adding 2 products at the same time!
NadorForum
If you add more than 2 products at the same time when you add the download file doesn't create a new thread in the specific forum.
example :
I add product A and product B at the same time. after that, I add a download file to Product A and B.
results: no thread created in the specific forum for new products.
Try to add 2 products without adding they downloaded fils.
after that try to adding the downloaded file.
Results: No threads created in the forum choosing for new products.
I hope you understand.
There are no problems with this feature. You need to make sure to fill out both the "Change log" and "Release notes fields, otherwise no thread will be generated.
For the initial download, it doesn't matter what you put in those fields as the initial release thread will always be generated from the product info itself.
4.86 star(s) 7 ratings
