Bug Issue with the latest images block on CMS
petandpet
I have 2 images uploaded into the gallery but on the CMS I see the widget without any images being displayed:
Sorry, got it figured out, I'll have it fixed in the next release. If you want to fix it yourself for now, edit the template dbtech_gallery_cms_images
Find
<vb:each from="<vb:each from="dbtech_gallery_img_data" value="image_data">" value="image_data">
and replace with
<vb:each from="output.data" value="image_data">
Find
and replace with
I am having the same issue but when I went to make the manual edit it looked as it should above. Would there be another issue.
Why you don´t try all the functions of your mod before release it?
I didn't make any modifications to the CMS widget in 1.2.x so I didn't think I needed to test it. It was broken with 1.1.3 and no one reported it so I didn't know.
are you sure both of them say output.data? There are two lines, one for verticle, one for horizontal
easiest way is to search the template for
Legacy DragonByte Gallery
