Question How to get load more button?
Okay but the script you are using is in the top stats by dragonbyte infopanels. Then it is custom code, if its custom code, can you guys add that similar functionality and if yes how much for it? If its reasonable i would happy to pay as I dont think its too complicated. Thanks
they are using*, it is your infopanels I checked the source code but they customized it then, but happy to pay for this as well customization if you guys can do it. thanks
DragonByte InfoPanels
XenForo 2.1.x XenForo 2.2.x XenForo 2.3.x
