Question General questions
stromb0li
I purchased DragonByte eCommerce and have a few quick questions:
1. Is there a way to enable/disable product reviews per product vs for all?
2. Is there a way to have time based user upgrades instead of permanent? I.e. when a customer purchases an item, it puts them in a group for a year then removes after the year?
3. Is there a way to restrict a purchase based on the members birthday? I.e only allow purchases for those 18 or older?
--Scenario, we'd like to offer variants based on member's age. I.e. if 13-18, then I'm eligible for a youth purchase; if 18 or older then I'm adult price; etc.
4. Is there a way to have a dependent purchase? I.e. if purchase A is made, then I'm eligible to purchase product B and/or C?
5. For coupons, is there a way to restrict use to a specific user (i.e. one-time promo code).
6. How do I change the url used by the add-on from dbtech-ecommerce to something shorter like store?
You will need to go to the AdminCP -> Products -> Permissions -> Registered -> "Review products": Never for each product to disable reviews for.
This assumes you are using a sane user group structure where everyone has "Registered" as their user group and any additional entitlements are gained by secondary user groups. If this is not true for your setup, you'll need to set that permission for any user group you use as "base".
Digital downloads (Licenses) allow you to set temporary user group changes that expire when the license expires. There are no such options for any other product type.
Yes, you can use secondary user groups for this. In the global user group permissions, set "Purchase products" to No and create a secondary user group for those over the age of 18. You will need to manually award this secondary user group, however, as the "User group promotions" feature in XenForo does not allow you to check someone's age, as far as I can tell.
Only if B and/or C are add-on products to A. If they are fully independent products, then no, not without a terribly complex secondary user group structure.
Yes. Click the "Permissions" link in the coupon list, tick "Private Coupon" and click Save, then configure the "Users with permissions set" to allow specific users to use the coupon.
Use the "Route filter" option in XenForo.
Hello @stromb0li,
4.86 star(s) 7 ratings
