Bug Fatal error after installing DB Credits for XF 2
dehness
The full error message is as follows:
Fatal error: Access level to DBTech\Credits\XF\Entity\Thread::_preSave() must be public (as in class ThemeHouse\QAForums\XF\Entity\Thread) in /var/www/vhosts/dev.thepiratesociety.org/httpdocs/src/addons/DBTech/Credits/XF/Entity/Thread.php on line 0
It's not a critical issue as the forum came back up fine after I disabled DB Credits by first disabling code event listeners in config.php, and it's only our development board anyway.
Obviously I'm just winging it here, but from the sounds of it, it's a file permissions/ownership issue, but I double checked and everything appears fine.
That appears to be a bug in the ThemeHouse mod, please report this bug to them so they can fix it. The issue is not in our mod.
Well, don't I feel like an idiot. Looking at the error now, that should've been the first thing I tried.
Plus I don't know if it's just me but I often find their products/code to be substandard.
Anyway thanks for the help, you were spot-on. I disabled that TH add-on and DB Credits now works perfectly.
I'll report the issue to TH.
Hello dehness,
5.00 star(s) 5 ratings
