Question Enable HTTPS
If you change your forum URL in the vBulletin Options to include HTTPS, then add this to your .htaccess file:
	RewriteCond %{HTTPS} off
	RewriteRule (.*) https://www.clubforo.com/$1 [R=301,L,QSA]
it should work fine :)
My .htaccess file:
<IfModule mod_rewrite.c>
RewriteEngine On
# RewriteBase /
# Options -MultiViews
</IfModule>
He tells me the page is redirecting properly.
Friend I'm using your seo plugin dragon lite.
Now I want my urls work with https, not http. Why I put your code that told me and I get the page is redirecting wrong.
In that case I don't know, sorry :(
Could you please try asking vBulletin support, as they will be more experienced in this matter? Redirecting from HTTP to HTTPS is 100% unrelated to DragonByte SEO anyway, so they shouldn't have any issues answering your query.
Sorry I couldn't be of more help :(
Hello zahiht,
