DragonByte Custom Navigation v1.1.0 Gold Released!
Ozzy47
Former Developer
After a successful beta period fixing a few small issues, DragonByte Custom Navigation is going Gold!!
DragonByte Tech is proud to present yet another addition to our lineup of great products, DragonByte Custom Navigation, available immediately for vBulletin 4.x.x.
This is a nifty mod that will allow administrators to add up to eight navigation items above the navbar like we have on DBT.
The mod is available here, DragonByte Custom Navigation - DragonByte Tech | vBulletin Mods & Addons or here vBulletin.org.
If you like the product you can show your support by nominating it for mod of the month here [DBTech] DragonByte Custom Navigation v1 (vB4) and also please rate it to help cancel out the users who 1 star our mods.
Why use DragonByte Custom Navigation?
There could be hundreds of reasons to utilize this product.
Say you and your staff want some navigation to be easier to find, no problem this mod is the answer.
You could also use it to allow your members to find some navigation items easier.
It can be used to work with usergroups, so if a member gets promoted, he would see the additional navigation items above the navbar, making them feel as if they earned something.
Major Features:
Multiple Navigation Items: Ability to have up to eight navigation items added to your site.
Item Target: Ability to set the target for each navigation item.
Usergroup Perms: Ability to select which usergroups see each item.
Custom Locations: Ability to show the navigation items anywhere on your site with a small template edit.
Complete Feature List (Lite)
  • Option to disable the navigation system completely.
  • Option to display version number you are running.
  • Option to enter the branding free if you purchased one.
  • Option disable "Runs best on HiVelocity Hosting" link.
  • Option to disable each navigation item individually.
  • Option to set the title for each navigation item.
  • Option to set the url to each navigation item.
Complete Feature List (Pro)
  • Option to choose from one of the following four predefined locations to display the items at.
    • Global Above NavBar
    • Global Below NavBar
    • Forum Home Below Forums
    • Global Above Footer
  • Option to set the target for each navigation item.
  • Option to add "no_follow" to each navigation item.
  • Option to set which usergroups can see each navigation item.
Discuss this news here.
