Bug Down-voted post when it shouldn't be
djvj
Happens on default skin as well, not that this is a skin-related issue.
Here is a direct link to the post in question:
RocketLauncher Forums
When I disable the thanks addon, post is fine. It happened with v3.3.1 before I just upgraded as well.
I do not have any dislikes enabled.
Update: This issue happened because someone modified the "(Pro) Post Collapse Weighting" setting to [thanks], which means that any post with any amount of Thanks button clicks above 0 will be considered downvoted.
I have restored the setting to its default value.
Hello djvj,
