Question Convert old links after installing
Now use a demo version
The properties found in the demo version itself have the properties in the paid and licensed version
Or is there a difference
Yes, all the features from the Lite version can also be found in the Pro version. The Pro version also contains additional features listed in the Feature List tab under "Major Features (Pro)" and "Complete Feature List (Pro)"
I wanted to buy a license
But after looking at the characteristics between the two versions there is no difference between them
Only in one property
It is that you can not write links and personal formulas.
I pay the sum of (US $69.95 ) because of this difference ...?
There are more differences than that as per the feature lists, but if you do not want to import your structure from vBSEO then you are free to not pay for it :)
I am ready to pay if I have a difference between the copy (pro) and ((Lite) from the work side
And that copy (pro) gives better results in engines better than copy (Lite)
It is unlikely the Pro version will give better results, since the core functionality (rewriting URLs and submitting to search engines) is the same. The Pro version is only for people who need the added customisations from the Pro version.
I am unable to replicate that issue anywhere, sorry :( There may be a mod conflict or a conflict with your skin.
I discovered the problem is disable the following options:
Hello abdurhman,
