Bug Branding Free system works
If you have a Branding Free licence for the product, attached to the same website as the main product, the branding gets stripped automatically on download of the main product.
I have Branding Free licence for all product from DragonByte Tech. But Why i am not getting Branding Free files?
I downloaded a fresh copy of DB Optimise from your client area and the branding is removed as expected. Can you please update your Security, Mail and Credits products as well? That would take care of the problem on your site, I reckon :)
Does have this issue? Site link not showing.
No, that is not the problem, that is irrelevant. If you click the Details link, you'll notice the Optimise product is not in that list, meaning its Branding Free system is working fine.
Can you please follow the instructions in my previous post?
I am doing soon, before please can you Un-Licence All product from my Default Site without XF product? I can not do this via edit site.
Sorry, I don't understand what you are asking. There is no need to take any action with any of the licences in your account in order for the new branding free changes to work.
I asked for un-check Site Licences box, I cannot do this, its checked the box after the save.
It is not possible for licences to not be attached to any site, sorry.
I want only check what i am using for this site, Now its hard to find out what for XF or vB.
Uploaded all files from Security, Mail and Credits products but still are not work branding free.
If no longer requires a separate key for remove Branding Free then why still downloadable [AddOn] Branding Free files? I think its best way to check or un-check from main product download page.
The 3 Branding Free licences were still set to the vB versions, I've switched them over. If you re-download those three and re-upload the files, then re-import their XML files again (both steps are needed), then it should correctly remove the branding.
Doing upload and import XML. Can we show XF and vB add-on seperate via Customer Area?
Honestly, I'm not sure why the Display Version Number setting exists - it's not used in any XenForo product. The Affiliate ID field is still used, but I don't have the ability to remove certain settings when downloading a Branding Free option so that setting will remain.
I'll go through our XF mods and remove the Display Version Number setting, and add the missing Security setting.
Also fix my [AddOn] Branding Free: vBShop and [AddOn] Branding Free: vBShout, Its still have set to the vB versions then switched them over to XF.
Legacy DragonByte Optimise
XenForo 1.5.3+
