Question Best Way to Rename Forum
Hi there,
When you say rename forums, do you mean:
  1. Change the actual name of the forum (e.g. "DragonByte Tech" to "NewCompany")
  2. Move the forum to another folder / a subfolder
  3. Change the domain of the forum (e.g. dragonbyte-tech.com to dragonbyte.com)
  1. This shouldn't require any changes
  2. You would need to add a .htaccess (or nginx.conf) rule that redirected the old URLs to the new folder. How complex these rules need to be depend on how your URLs are set up.
  3. You'd need something like
    	RewriteCond %{HTTP_HOST} !^www\.dragonbyte-tech\.com
    RewriteRule (.*) http://www.dragonbyte-tech.com/$1 [R=301,L,QSA]
Hope that helps :)
No... I mean the name of a forum inside the forum, not the site name......
In vBulletin, a "forum" is one of the forums set up in the forum, not the site name.
For example:
http://www.unix.com/linux-open-source/
is a forum .... "Open Source"
I want to change the name, for example to:
"Linux Open Source"
so the new URL will end up
When I did the before (DBSEO running today), it seemed to cause a lot of problems.
I thought DBSEO automatically took care of this; but I was wrong; so I guess I did it wrong.
Oh, I see, sorry :(
Thank you for the explanation :) With no further detail in your first post, and plenty of people referring to "a forum" as the site as a whole, I made an assumption.
Hopefully you can forgive my mistake :)
DBSEO can only do this automatically if you include the forum IDs in your URLs.
You should be able to redirect it to the new SEO'd URL by using the "Custom Redirects" feature:
'^open-source/' => 'linux-open-source/'
Some refinement might be needed if you need to include URL query parameters, but it uses normal regexp syntax :)
Hello neounix,
