Hey all,
Hot on the heels of v1.1.0 comes a minor update, v1.1.1.
AJAX Threads v1.1.1:
Fix: Using "Newest First" post order had multiple deep-rooted issues
Fix: Posts deleted when hitting the "max posts" setting should now behave more consistently
Change: (Lite) There is now an option to disable the HiVelocity Hosting link if you do not wish to support DragonByte Tech by having it displayed. This setting has no effect for the Pro version.
The HiVel setting will be added to more mods as they are updated
Thank you for your continued support
Discuss this news here.
